Pipe Centerline by Dynamo Script
Hello
Is there any script available which can add centerlines in pipes with desired linetype and color? It should be independent of any filters/system graphics applied to outer edges of the pipe.
I am looking for a solution to my issue
Avik
Hi
Please read this first.
I’m not a Revit guy so I can’t help you but if you want to get help this thread is a good start.
Maybe this can help you to start.
Hi find you pipe location curve, use detail line by curve or modelline by curve ? and change your line to what you want, but i would just do it with categori override and turn CL on and give a pattern and color
