Guys, I’m trying to create a line at the center of the pipes. However, the line works in the first view I create, but I can’t replicate it for the other views. I thought about using it in all the plant and section views.
Thank you for everything, folks.
Use a ModelLine instead of a DetailLine.
ModelLine
DetailLine
Thanks for the tip, but I don’t know which node to use to turn this into a model line.
Instead of DetailCurve.ByCurve you want ModelCurve.ByCurve.
DetailCurve.ByCurve
ModelCurve.ByCurve
In my dynamo this option does not appear, it is some pack?
Is it not that first one? It’s a core Revit node.
Parts of it worked, but in one of the views, it is visible in the foreground, in the others, it’s present but underneath.
It’s a 3D model curve. It has 3D coordinates, so you need to draw it at the the correct offset.
