Can anyone help me with this? - because , I m currently not able to get any level or spot elevation when I import the 3D CAD file into Revit.
Any screenshot, illustration, link…?
Yes , please find below the screenshot to understand more:
Part_2 IMage is to show the level on the 3D AutoCAD file
Is there a way to generate points from 3D CAd file using Dynamo and using these point- Can Dynamo generate a surface or a Mass from which the spot elevation point can be picked out???
You can check if BimorphNodes or LinkDWG packages have nodes that would help to meet this goal. But I would suggest to see first on AU if any solution has already been exposed, for instance:
Is there any reason you are not just using the pick reference dwg function for topography creation in revit? Once created, spot elevations on the revit toposurface should be possible.
Otherwise, using the element.geometry node is a good start.
See also this recent post:
Thank you for your reply.
The reason - why i am not using pick refernce is that while using Topgraphy, It cannot create vertical faces.
Like In the images that I have attached - There upstand kerbs all around the surface.
If I use topography - The topography will straight away jump to the next low or highest point.
Thank you … The link which you sent me worked pretty well for me.
You saved me… Cheers
