Civil 3D to Revit by Dynamo
Is it possible for us to create a:
  1. Convert the block into a points then export the coordinates using dynamo in civil3D
  2. Import the data from the excel file to Revit by those points.
2nd Phase
What if I have a rectangle block rotated.
I want to extra a point with the angle in civil3d.
Then import it in Revit?
I would like to automate how I create model from AutoCAD or civil3D to Revit.
I think the community will benefit more in this script.
I appreciate your help all.
Cheers,
Rod
Hi @JQXZ4Q,
Check out the CivilConnection package. Documentation here.
Autocad can generally do this using good block/family design, and the dataextract command. Dynamo wont make good blocks/families for you, make sure you get that part right first and the rest is just data/list management
I have a Family that are already in Revit. I just need those script to work with both Civil3D and AutoCAD.
But I am not sure how and I have a time frame to work on it. That is why if I can grab anything on anyone to work with that will be a big help.
Try this sort of approach. It relies on having consistent block origins, names and rotations.
If you are working to a deadline ensure you have time to manually achieve this if you are not familiar with dynamo. Dont try to learn it in a rush as its a hard program to learn that way.
I think this is it what I am looking for. I will try to work on it at my satisfaction.
I very much appreciate your expertise.
Cheers,
R
