I gave a shared parameter of checkbox to the element for judgement.
But I can not get the value of checkbox with node called “Element.GetParameterValueByName”
How can I get the value of checkbox?
Hi @t_mitamura can you show your issue with a graph?
Cheers
Hi @t_mitamura
maybe try get parameter value as string or get parameter value as unit from mepover package.
Cheers
See the link below for reference
Space Imported Specified Return/Supply Airflow from excel, conversion?
Normally you get at output 0 or 1 (uncheck or check)
Cheers
Hi @t_mitamura I tested the OOTB node “Element.GetParameterValueByName”, works as expected return 1 if checked and 0 if not checked.
Cheers
Thank you for your reply.
I cannot get values still.
Would you please confirm .rvt and .dyn.
https://drive.google.com/file/d/1NFo5DMFIcjyAkkvwiRLKjsTW1D0zIyP9/view?usp=sharing
Regards
T.Mitamura
Thank you for the information.
how can I get it?
Hi @t_mitamura here you go
Paris
Thank you for the graph!
I could get the value of checkbox.
And I will be able to get a lot of values I want with your graph.
Regards.
T.Mitamura
Hi @t_mitamura,
you are welcome, can you mark the post as solved?
Cheers
