I’m trying to filter a number of specific doors (using GetParameterValueByName) which have a yes/no parameter (shared) applied to them by using a boolean mask. For some reason I’m getting blanks in the results while I’m expecting a number of true’s.
Can someone explain why this isn’t working how it does for other parameters? The parameter in question is only applied to a number of doors and it’s a shared parameter.
I have gotten around it by using a Elements.GetParameterValueByNameTypeOrInstance node but I’m just curious to why the OOTB node doesn’t return the same?
Is the parameter a Type parameter? If so, then you would need to first get the Element.Type from the All Elements Of Category node, then use the Get Parameter node.
