it gets null as well for every Revit element in a revit link if using getparametervaluebyname “Family and Type” , I am wondering if that function to get parameter value does not work for linked elements. I tried myself with OOTB dynamo nodes and does not work directly, what I was able to do is to get Element.Parameters, convert them to string and search only the results of parameters of elements that contain or start by string "Family and Type : ", so i take the value string and remove the part "Family and Type : " from it so I get the clean string value, but this looks very excessive silly processing I am sure must be a more direct way to get the parameter value from revit linked elements?
try clockwork element.type node
@rrvivancosWTL pretty much looks like this, nearly identical to how you would do it in a local model. You just need to GetLinkDocument()
links = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()
first_link_doc = links[0].GetLinkDocument()
elems = FilteredElementCollector(first_link_doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
OUT = elems[0].LookupParameter("Family and Type").AsValueString()
yeah easy thanks.
I tried also this different solutions:
param = e.get_Parameter(BuiltInParameter.ELEM_FAMILY_AND_TYPE_PARAM)
if param and param.HasValue:
identification_name = param.AsValueString() # Use AsValueString() instead of AsString()
identification_name = None
also this:
# Identification_Name by scanning parameters
param_prefix = "Family and Type : "
# Loop through all parameters of the element
# Note: For linked elements, 'e' is still a Revit element from the linked doc.
for p in e.Parameters:
# Try to get a parameter value as string
val = None
if p.StorageType == StorageType.String:
val = p.AsString()
if val is None: # If not a string param, try AsValueString
val = p.AsValueString()
# If we got a value and it starts with "Family and Type : "
if val and val.startswith(param_prefix):
# Extract the substring after "Family and Type : "
identification_name = val[len(param_prefix):].strip()
break
