How to get the center lines between the DWG parallel lines after linked the DWG file into revit with dyanmo? Thank you very much!!! (26.0 KB) parallel lines.dwg (138.1 KB) Project for question 1(version 2019).rvt (3.0 MB)
How to get the central files between these parallel lines.dyn (26.0 KB)
There are two packages you need
First is a package by @Thomas_Mahon, called Bimorph
Second would be a package by @Alban_de_Chasteigner, named GeniusLoci
Next is to use the search button here on the forum, just type “center lines” and read all you can.
Good luck.
Thank you very much! I will read it first and try it.
