Hi, I am trying to get boundaries from this solid desk but It’s not working with me
@Deniz_Maral @jacob.small Can you help me to solve this Please?
Thanks Deniz I appreciate that so much
everything worked well but when I try to make run to true to export it to AutoCAD that what I want… the dynamo not responding and then Revit has closed. what can I do to solve this?
Why don’t you export as SAT and import to dwg?
I got it but I want to target dwg to manage layers and colors as one shot
I see, which package is that? I should check what it includes.
ExportGeometry from LinkDWG Package
actually It’s working with all curves but maybe curves on desk to much so we need to minimize number of them or find a way to find top boundary of desk just I need to export it as plan
Element.Faces
to get the surfaces.
Surface.PointAtParameter
to find the point at the center of the surface’s domain.
Point.Z
to find the elevation of each point.
List.SortByKey
to sort the surfaces by the Z values.
List.LastItem
to pull the last surface from the reordered list.
thanks, @jacob.small but It’s not working with me
Watch your list levels and lacing.
The error likely says something like “list as keys are not supported” because you’re feeding a list of objects in as the key. Set the keys inout to @L2 and see is that works.
Try setting both inputs to @L2, or flattening both lists.
@jacob.small ok finally it’s working but maybe I have a conflict about why the number of the lists has the same value at start and end I think I need to reduce this number from all surface I need just top plane
Watch your list levels again.
