Hello everbody
I would like return which elements are from some surfaces. I use as a example this topic:
But, it’s just for one surface… I made something like that:
However, it’s return a error:
This a correct way for return all elements from surfaces or there other way?
Hi @brenofilipe,
Looping to get the “i” in the range is not going to help you unless you use that “i” to retrieve the element from ref.
Try this:
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
# Import ToProtoType, ToRevitType geometry conversion extension methods
TaskDialog.Show('Selection','Select the face(s)')
refs = uidoc.Selection.PickObjects(ObjectType.Face, 'Select the face(s)')
output = []
for ref in refs:
out = []
elemId = ref.ElementId
element = doc.GetElement(ref.ElementId)
dynSurface = doc.GetElement(ref).GetGeometryObjectFromReference(ref).ToProtoType()
out.append(elemId)
out.append(element)
out.append(dynSurface)
output.append(out)
OUT = output
This is exacly that I needed.
Thank you very much @AmolShah !
