Hello
I’m trying to get a parameter for the new Dynamo 1.2 node ParameterFilterElement.ByRules but it throws an error as shown on the attached image. How do you get a Parameter from a Parameter Name? Thanks
It is possible that there is an error with the new ParameterFilterElement.ByRules. Each time I manually change the System Abbreviation the element IDs (circled red) remain the same. This means that my filters get overridden each time Dynamo is run. Shouldn’t these IDs be changing for new Parameter Filters?
I have also tried to search for existing ParameterFilterElements but I can’t work out how to extract their Names:
I’ve solved the Name problem by using the Element.Name node. I have also made the routine create a TemporaryFilter if the ParameterFilterElement already exists. The routine works BUT will still overwrite existing Filters due to the node generating the same Element IDs (as I circled red in an earlier post). Is this a bug in the new ParameterFilterElement node?
