How can I put together a graph that gives a consistent result when applied to ceilings ? I get two different results if the ceiling is a simple ceiling or a compound ceiling. At the moment the Element.Geometry works for a simple ceiling but not for compound ceilings.
Result from a Simple Ceiling above and the result from a Compound Ceiling below.
To get all of the surfaces of a geometry, you can use Element.Faces
This will include bottom, top, and all of the sides so you may need to filter using the normals to get the one you want.
Thank you to @kennyb6, you have succinctly pin-pointed the issue, and cleared up my problem.
This is actually an extension to the graph provided by @andre.abotnes, Push-room-name-to-Ceiling but I found it didn’t handle Compound ceilings, so I thank him for the earlier work, and hopefully this provides a more generic solution.
NAME_CEILING_FROM_ROOM_NUMBER.dyn (47.1 KB)
BASIC_CEILING.rvt (2.1 MB)
COMPOUND_CEILING.rvt (1.3 MB)
