How to disable halftone setting in a view template?
In a view template i want to change 2 items in the “V/G Override annotations”
  • uncheck Dimension
  • uncheck Textnote
I really have no clue which node(s) i have to use.
Hope someone could help me here.
thnx
This should do the trick:
thank you that did the trick
just for learning but is there also a way to get en set all the categories in V/G overrides model and V/G overrides annotations to halftone?.
thnks
after doing that above trick the error is coming could you please explain why
