How to create section box
I’m not finding any way to create a section box using dynamo nodes.
Is there a way to create a section box around two clashing elements using nodes/ python?
or is it possible to create a section box from bounding box?
So I actually use this add-in for sectioning. I’ll select the elements and then hit Auto Section Box (shortcut:BOX).
But automating is most likely possible. Do you have a clash-detection script that you use, or how do you select the clashed content?
Can you share a screenshot of what you have so far?
View3D.SetSectionBox is GeniusLoci will do what you need.
You just need to input a bounding box box that’s derived from your 2 clashing elements, and either your active 3D view if it’s a one off, or you could use Dynamo to create a bunch of 3D views in bulk for a series of clashes.
I’m not sure what I am missing but I don’t see a View3D.SetSectionBox node from GeniusLoci
I’m using Revit 2021 and have Genius Loci (2022.2.103) installed.
The 3DView by BoundingBox node should do the trick.
That seems to have worked! Thank you!
