How to create hexagonal panels by lists of points?..
Have you tried those “ByPoints” methods? E.g., Polygon.ByPoints(), PolyCurve.ByPoints()?
Yu Ke,
Thanks for your time. I did, but i don´t know how to manage lists…
Cheers.
Hello René Castillo Picazo,
If possible can you post a picture of your graph and explain what you want to achieve.
Thanks,
Ritesh
Ritesh,
Thanks for your response.
I need to create a regular hexagon panel, but the surface pattern in Revit creates an irregular hexagon.
I created an hexagon pattern like this:
… but the component doesn’t fit in the borders (surface)
In Dynamo, i created a simple surface with a UV Grid, but i don´t know how to manage lists to connect each 6 points to create the panel. I have not the definition right now, but I’ll upload the file the next time.</span>
Thanks.
René,
