How to create diagonal wall with dynamo
I want to create this diagonal wall with dynamo, so I tried to extract edge from the wall, using SelectModelElement, which i can change the Z point of the edge, but I couldn’t find the node for extracting edge.
I even downloaded GeniusLoci package, but it doesn’t work, keep saying edges are null.
Could anyone please give me a help?
Thank you.
This is the loci package I used.
Hi Claire,
The code of the Wall Edges References node was written using the Python 2.7 engine.
So the DynamoIronPython2.7 package version 2.5 must also be installed for the custom node to run, as explained in the package description.
Thank you for your fast reply. @Alban_de_Chasteigner
After I read your reply, I downloaded the DynamoIronPytnon2.7 package and tried again, but didn’t work.
I’ve created wall in Revit, and want to extract edges to change the edge point so I can create diagonal wall.
Is there a solution for the package or any solution for creating diagonal wall?
Thank you.
Hi
you can try this track new wall
Sincerely
christian.stan
Thank you for your help!
I really appreciate it.
Thank you :slight_smile:
OMG it worked!!! Thank you so much :slight_smile: I am so happy.
I appreciate your kindness.
Thank you!
hello
I used this python code to create diagonal wall, and created successfully.
However, what I originally wanted to do was to extend and reduce the size of the wall freely.
It also works well, but the problem is, if I extend and reduce it, the wall that I just extended also exist on the revit, which originally does not have to exist. I don’t want to delete the useless wall, that I created before, one by one.
Is there a solution for this as well?
Thank you
Also, I wanted to use this python code to create tilted ceiling. So I edited the code like this, but doesn’t work. How can I solve this problem? Could you please help?
Thank you.
Here is the code:
import System
clr.AddReference(“RevitAPI”)
clr.AddReference(“RevitAPIUI”)
app = uiapp.Application
curves=IN[0]
level=UnwrapElement(IN[1])
type=UnwrapElement(IN[2])
typeid=type.Id
levelid=level.Id
profile=ListCurve
for curve in curves:
profile.Add(curve.ToRevitType())
wall=Ceiling.Create(doc,profile,typeid,levelid,False)
OUT = Ceiling
Hi, if you want to modify the profile of your wall,
Check that the sketch is modifiable
You have a method in the Wall class
you will need
its skecthId (wall property)
Recover your skecth
Use the SketchEditScope Class
From what I understand, nothing is set in stone, I’m still babbling
It doesn’t seem that simple, I’ll try to dig deeper next weekend
Try it on your side in the meantime
Try not to digress in your post, people looking for it need to be able to find their way around it.
Sincerely
christian.stan
I did some research but I have a transaction problem that I don’t really understand for SketchEditScope
Here is
the data:
import sys
clr.AddReference("RevitAPI")
wall_initial=UnwrapElement(IN[0])
prof_new_wall=IN[1]
cond_bool=wall_initial.CanHaveProfileSketch()
sketch_wall=doc.GetElement(wall_initial.SketchId)
if sketch_wall==None:
    sketch_wall=wall_initial.CreateProfileSketch()
    doc.Regenerate()
    out=[i.ToProtoType() for i in sketch_wall.Profile]
a=[i.Reference.ElementId for i in sketch_wall.Profile[0]]
sec=SketchEditScope(doc,'Delete and change the lines')
#open editscope
sec.Start(sketch_wall.Id)
#Delete the Lines
for i in a:
    doc.Delete(i)
#Send the new Lines
for i in prof_new_wall:
    doc.Create.NewModelCurve(i.ToRevitType(),sketch_wall.SketchPlane)
sec.Commit()
OUT = cond_bool,out,a,sketch_wall
edit:
before the transactions
Sincerely
christian.stan
How to write the instruction circled in green in CPython
Sincerely
christian.stan
Hi Christian,
I’ve encountered the same issue you mentioned regarding the use of the Commit method in SketchEditScope when attempting to edit the sketch profile of a wall. Unfortunately, it seems that not many people have worked with this procedure before.
Were you ultimately able to use it successfully in Dynamo?
Thanks in advance for your input,
Bash
This will remain too cryptic for me; there’s no way to make it work.
Sorry, I won’t be of much help.
Sincerely,
christian.stan
Here an example
edit_wall_profile
python code (IronPython3 or PythonNet3)
No solution with CPython3 (especially with Revit 2024)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
class CreateFailureAdvancedHandler(IFailuresPreprocessor):
    __namespace__ = "CreateFailureAdvancedHandler_jdtR0sA"
    def PreprocessFailures(self, failuresAccessor):
        failMessages = failuresAccessor.GetFailureMessages()
        if failMessages.Count == 0:
            return FailureProcessingResult.Continue
        transName = failuresAccessor.GetTransactionName()
        if failuresAccessor.GetSeverity() == FailureSeverity.Warning:
            for currentMessage in failMessages:
                failuresAccessor.DeleteWarning(currentMessage)
        elif failuresAccessor.GetSeverity() == FailureSeverity.Error:
                failuresAccessor.ResolveFailure(currentMessage)
            return FailureProcessingResult.ProceedWithCommit
            pass
wall = UnwrapElement(IN[0])
offset_value = 5
# offset point
TransactionManager.Instance.ForceCloseTransaction()
sketch = doc.GetElement(wall.SketchId)
curveArray = sketch.Profile[0] # assuming there is only 1 loop
# get top line
sort_curves = sorted(curveArray, key = lambda x : x.Evaluate(0.5, True).Z)
top_line = sort_curves[-1]
rest_curves = sort_curves[:2]
# get points on top line
pt1_old = top_line.GetEndPoint(0)
pt2  = top_line.GetEndPoint(1)
# find adjacent vertical line
vertical_line = next((c for c in rest_curves if c.Project(pt1_old).Distance < 0.01), None)
# bottom point on vertical line
pt3 = next((vertical_line.GetEndPoint(i) for i in range(2) if  vertical_line.GetEndPoint(i).DistanceTo(pt1_old) > 0.1), None)
new_pt = pt1_old - XYZ(0,0,offset_value)
new_top_line = DB.Line.CreateBound(new_pt, pt2)
new_vertical_line = DB.Line.CreateBound(pt3, new_pt)
sketchEditScope = SketchEditScope(doc, "Update Wall")
sketchEditScope.Start(sketch.Id)
t = Transaction(doc, "Update Wall")
t.Start()
# Remove elements referenced by the found lines.
doc.Delete(top_line.Reference.ElementId)
doc.Delete(vertical_line.Reference.ElementId)
# Model curves creation automatically puts the curve into the sketch, if sketch edit scope is running.
doc.Create.NewModelCurve(new_top_line, sketch.SketchPlane)
doc.Create.NewModelCurve(new_vertical_line, sketch.SketchPlane)
t.Commit()
sketchEditScope.Commit( CreateFailureAdvancedHandler() )
t.Dispose()
OUT = wall
Hi, thank you very much for spending time on this issue.
Sincerely,
Christian.stan
It’s going to take a lot of effort for me to understand the structure of the class. (Great, I’ll make even more progress.)
Sincerely,
Christian.stan
