I have an idea to create diagonal dimension lines for this wall in the section view environment of Revit. I have obtained the 4 corner points of the wall. I tried using the nodes available in the package but it didn’t work. Do you have any solutions to he
We don’t see anything from your screens
(zoom so that it is visible before using it
doesn’t matter if you don’t see all your nodes)
here is a potential avenue
code Block
S.X==C.X
S.Y==C.Y;
Sincerely
christian.stan
Hello @MeoTom and welcome
iw ould try something here
hello, I’m going to go back to bed, I was way off topic (I hadn’t seen the Dimension)
cordially
christian.stan
heheh yeah it was a long one the headline
but sleep well
a solution using edges Reference
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
import itertools
def most_distant_pair_edges(wall):
global opt
horiz_edges = []
for geo in wall.get_Geometry(opt):
if isinstance(geo, DB.Solid):
print(geo.Volume)
for edge in geo.Edges:
curve_edge = edge.AsCurve()
if isinstance(curve_edge , DB.Line) and abs(curve_edge.Direction.Z) < 0.1:
horiz_edges.append(edge)
pair_edges = [[e1, e2] for e1, e2 in itertools.combinations_with_replacement(horiz_edges, 2)]
sort_distant_pair = sorted(pair_edges,
key = lambda x : x[0].AsCurve().Distance(x[1].AsCurve().Evaluate(0.5, True)),
reverse = True )
# returns the 2 most distant pairs
return sort_distant_pair[:2]
def toList(x):
if isinstance(x, (list, dict)) or \
(hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
return x
else : return [x]
lstelems = toList(UnwrapElement(IN[0]))
current_view = doc.ActiveView
out = []
opt = Options()
opt.ComputeReferences = True
opt.View = doc.ActiveView
for wall in lstelems:
for edgeA, edgeB in most_distant_pair_edges(wall):
pta = edgeA.AsCurve().Evaluate(0.5, True)
ptb = edgeB.AsCurve().Evaluate(0.5, True)
base_line = DB.Line.CreateBound(pta, ptb)
refArray = ReferenceArray()
refArray.Append(edgeA.Reference)
refArray.Append(edgeB.Reference)
dim = doc.Create.NewDimension(current_view, base_line, refArray)
out.append(dim)
OUT = out
