How to create a project parameter in Revit 2026
Translated by moderator. See. Slow the line for original post.
I can’t create a project parameter
Original post below
No puedo crear un parámetro de de proyecto
Welcome to the forum @Roy.guevara.78!
Sadly, the official forum language is English (annars skulle jag bara posta på svenska så att jag kunde öva). This is a technical requirement to make search work. Please translate future posts to English, optionally keeping your native language post separated by a line or other demarcation as I did in the edit of your post.
Thanks!
Unfortunately, there is no way to create project parameters via the API in Revit, which means you cannot directly automate it with a Dynamo node, scripting, or C# code.
Instead, I recommend you create a shared parameter which should be more readily doable.
