Create project parameter confused with shared
Followed a number of posts that did really identified some issues but no workaround. I have been trying to create project parameters within Dynamo unsuccessfully. I get the parameters created but they are shared parameters in Revit 2017.
The Createprojectparameternode is the same as the shared parameter node. can this be used to create a project parameter? I am trying to create columns for a development/lap length schedule ideally without Python.
Is the group name the issue?
There is currently no way to create project parameters without using shared parameters via the Revit API.
https://forums.autodesk.com/t5/revit-api-forum/create-project-parameter-not-shared-parameter/td-p/5150182
Hi Andreas thanks, I’m not great with Revit, I did a good search at the weekend and didn’t really get anywhere. It is a shame as it looks as though it’s not a massive amount of work. I probably can work with shared parameters just a little more work.
Kenyon
