Creating a Project Parameter
Hi Guys
iam facing a issue on creating a project parameter
I created a Parameter using Parameter Create project parameter node
and manually aside
when i try to modify it is showing as shared parameter why ?
created manually
Created through Api i.e dynamo
thanks in advance
You cannot create a true project parameter with the API. That node’s name is misleading and is not accurate.
Refer to:
https://forums.autodesk.com/t5/revit-api-forum/create-project-parameter-not-shared-parameter/m-p/5152374/highlight/true#M6777
Note: I am not too sure what the thoughts were around that node when it got created, but it definitely needs revised/fixed. CC @solamour @Zach_Kron
T :+1:hanks john
