I am trying to model the Oppo HQ by Big Builds, by using dynamo. https://big.dk/#projects-oppoh
As you can see on the following image, I have tried to make a surface in Revit from a Dynamo loft surface.
However, it does not seem to work as nothing appears in Revit.
Can someone guide me through this?
Did you resolve this? I too am trying to get a Dynamo mass from Dynamo into Revit using Curtain walls but I can only find tutorials using adaptive families
If you have already the surfaces there’s an option to create a Mass category family instance and then create wall by face and the swap the wall family type for something curtain wall type
Hi… could you show an exemple ?? with that as i cant get it to work, even manuelly when the wall by face is inserted from dynamo…but think it could work with walll by profile…
