Hi All,
Any one can help me how o convert solid element in Revit with Dynamo to Rhino with Grasshopper? for example I want test with some beams or column or Stair
Thanks all
Hi All,
Thanks all
Not sure what you are exactly after but i would consider gettings point in Rhino and use that to genereate beams in Revit through Dynamo. No need for “solid” conversion
You could use the Rhynamo package from dynamo to rhino and then reference in GH. Or you could get the face vertices and stream out of Dynamo via csv or similar text file and rebuild in GH.
