How to combine lists in this way?
Combine elements in the corresponding sublists as shown in the pic.
Use original Dyanmo components (no 3rd patry components or python code) is preferred.
In this simple example, there are only 2 sublists in each list.
In real world, I have more than 100 sublists in each list.
Thank you
Try the node List.Combine:
https://dictionary.dynamobim.com/2/#/List/Match/Action/Combine
Hey, could you solved the problem by using the combine node? I have read and tried it but couldn’t make what u wanna do. I have the same problem as urs.
Yes I solved by just following the example in the https://dictionary.dynamobim.com/2/#/List/Match/Action/Combine
