Weave or Merge several jagged sublists
Hi There,
I have several lists with either one or many sub-lists. I would like to merge the lists together such that each set of corresponding sub-lists are added to the end (or start) of the first list. I don’t want new lists to be created. Each of the options i have tried (List.Combine, List.Join, List.Create) result in extra lists rather than adding the items to the list.
List.AddItemToEnd almost works, however i would like to node/function "List.AddMultipleItemsToEnd to avoid copy pasting nodes.
See image of simplified example below and the desired output
Forum won’t let me attach .dyn file yet.
Any tips greatly appreciated!
I fixed it by repeating the last list, and joining using a python node.
see screen cap below:
Cheers,
Dharman
Hello, there also useful information about lists in the Primer if needed:
http://dynamoprimer.com/en/06_Designing-with-Lists/6_designing-with-lists.html
Thanks, I missed that section. some nice graphical explanations!
Here are two more alteratives for you!
