I have created a family that needs to start at it respective levels, and end at the level above. I decided to solve this with Dynamo, using the following roadmap:
Select all family elements> find base level> set top constraint to ‘base level+1’
seems fairly simple. I’m sure this is really simple, but I can’t figure it out. I’ve got as far as isolating the base levels, and converting that list to a list of strings. I just need to isolate the “Level” information in the string in order to proceed, but I can’t seem to figure out how.
Questions:
-is there a way to set the family height to match to the level above without the use of dynamo?
-how do I isolate text from a string (keeping in mind there is text in front, and behind the text I wish to isolate), so remove wont suffice.
