I have a small question: I have a Family type that I want to use as an input into an “FamilyInstance.ByPoint” node.
But I get an error because the familytype needs a reference level.
Can I put a “Element.SetParameterByName” in front of the node and set the Base Level to the correct level?
And if so will the output still be a FamilyInstance?
Or must I add a piece of code (like: “reference_level = L000_S-top”) to the family type string via a code block?
Hahahahaso it was a stupid question from me! Hahahaha.
But then…Yes it is a OOTB node!
I prefer to use only the nodes from Dynamo itself and as less custom nodes from packages as possible.
IT WORKED!!!
Thanks for your help!
But now I still have an error message but only at the end. I’m trying to alter the family parameters with the “Element.SetParameterByName” node and I’m using a “code block” node to set the ParameterName and the Value.
But I get the error that the “Parameterl’s storage type isn’t a string”.
I want to change the Constrains “Base Level” and “Top Level” and the “Top Offset” from the family.
Is the error telling me that I’m giving a string into the node and that’s not correct?
Or the items I wanne change can’t handle a string because the need a Level as an input?
Just don’t use “”. If you use them in your code block, then it’s a string. If you don’t, it will be considered as a Double or an Integer.
Using an Object.Type node can also be sometimes useful to identify the type of a Dynamo element (for instance after a GetParameterValue node, it will show the Dynamo type of the resulting items).
