I’m looking for the parameter to change the Revision of a Revision Cloud. Simply using “set parameter” does not work.Revision Cloud Change Revision.dyn (7.7 KB)
You are nearly there.
Instead of using the Parameter.Name node, feed the required revision into the Value input to set the parameter. For the parameter name input use a string “Revision”
