Hi
I like to import the geomerty and layers of multiple DWG into dynamo. I hold push the geomerty through an equation and generating a new geomerty for each loaded dwg puching them back out into seperate dwg again.
So how do I do step 1. import the geomerty of layers of multiple dwgs?
I dont think thereis a way to,check this post.
I’d like to import cad file in dynamo.
I also tried to googing for information that refered Fileloader.frompath node but i can not find that node.
Is there anybody know that node?
Hi there were a lot of nice things there but the marco did not work
As you see I used the CVS file but it adds a . in the end and it can’t create a link
Could you email me the CSV file you used? I’ll take a look. My email is michael at archsmarter dot com.
hi can you tell me plz where did you find this nodes:
file loader. from path
file loader.ge import to object
imported object . convert to geometric
you can find it in Dynamo studio. Refer to this page: Importing Geometry | The Dynamo Primer
lasse
January 30, 2023, 8:50am
8
How do you find this node? I cant find it in packages and your link is broken thanks!
you can read it from this article: Importing Geometry · GitBook
FYI: these nodes are only available in Dynamo Studio but Dynamo Studio is no longer available. It has been removed from the Autodesk AEC Collection.
lasse
January 31, 2023, 9:16am
10
So there is no way to import dwg files into revit anymore ??
Use the Genius Loci package with the Link DWG or Import DWG nodes.
lasse
January 31, 2023, 9:29am
12
So this one doesnt seem to import anything, anything else i need to do with the importinstance maybe? SOrry for the noob questions
Please use the search button and/or read the Dynamo Primer .
lasse
January 31, 2023, 9:33am
14
I know those, thanks! I just wonder how to get the geometry out into the scene!
Working with .sat files was similar but i got the import right ahead
It should be like this one and it works fine for me
lasse
January 31, 2023, 2:20pm
16
Mine looks like this and nothing gets imported sadly…
Remove Document.Current node.
You don’t need it and it is not the right kind of document.
lasse
January 31, 2023, 3:37pm
18
Cool! This works but i have one more question. How come i cant see the model in the 3d view?
I can see it in the “regular” view
@Alban_de_Chasteigner
Please answer here:
Thanks! Doing something like this but i cant seem to see the imported object in the 3d view. Only in the regular view and its like locked?
Otherwise we have redundancy
