DWG Import in Dynamo Studio 2019
Hi I followed the instrutions of importing geomerty in Dynamo studio i have a dwg made which dose not want to get imported what am I doing wrong?
test.dwg (42.6 KB)
http://primer.dynamobim.org/en/05_Geometry-for-Computational-Design/5-8_importing.html
Hi @johannaroenner
Could show us previews for all nodes.
Did you mean Dynamo Studio 2017?
Hi I changed to Dynamo studio 2017 and autodesk Autocad 2017 and it works. I was not the Dynamo 2019 that was the problem cause it could read the old Autocad files but it could not handle autocadfiles dwg. from autocad 2019
This is because the dog standard changed in 2019. You’ll find you also have issues importing a 2019 dwg into a 2017 Revit version unless you save down the file format.
How do you get the fileloader nodes?
They only existed in Dynamo studio, which was discontinued about 2 years ago.
Best to utilize Dynamo for Civil 3D instead.
Damn… what is Dynamo for Civil 3d?
Hallo
Yes it was long time ago in Dynamo Studio.
civil 3D Download Civil 3D 2023 | Civil 3D Free Trial | Autodesk
It is usally enough to use Dynamo i Revit. To get geomerty by catagory
Skjermbilde 2023-01-30 143213
