I will just change the wall end from normal to round at the end.
Like the pic. Please tell me a script.
Thank you…
You mean making a wall based on an arc instead of a line? It is the same as creating any wall, just use the arc instead. Please try making a script.
Yes exactly Kennyb6, we can do it in revit witg “Draw” but can we do it in Dynamo?..
The purpose of it will be to change all the walls of the project. with dynamo
We try to do that… but in dynamo?
You would have to actually make the curve in Dynamo and create the wall using the curve. How you make that curve is up to you.
