How create a filled region on wall elevation in dynamo
How create a filled region on wall elevation in dynamo?
This one should do it for you.
How to do in dynamo?
Oh sorry i misunderstood the question.
This should get you started.
¨Hello @Vivek_Manika_Sudhars and welcome to the forum, best you show what you have tried so far in dynamo…but something here could get you started, if you are new in dynamo then i suggest go through primer in help as well
Revit_lxxgAZFHb5
Hi @pyXam ,
I apologize, but I’m not familiar with how to use the Dynamo forum yet. I attempted to post about how it works, but I also have a question, as I am new to Dynamo and currently learning. I will make sure to post properly next time. Thank you for your understanding and for providing me with information.
Hi @Sovitek,
Thank you for taking the time to answer my question. I’m grateful to see the Dynamo scripts you’ve provided, but I encountered some errors. I’ve attached a reference image for your review.
something here with opening maybe :wink:
Hi @sovitek,
I’m encountering an issue in Revit 2022 with Dynamo. The Polycurve.ByGroupedCurves node is not available. Do you know of a solution or alternative for this?
Yeah try group curves from archilab
@sovitek Its shows error
IMG_8665
Can you share your graph ?
FYI @sovitek
Create Filled Region on Elements Face2022.dyn (13.5 KB)
Hi @Vivek_Manika_Sudhars try as here, should work in 2022
