Civil 3d python node
Hello
What is a proper way to invite Civil 3d objects and existing Civil 3d nodes in python script ?
Revit example from primer:
# Import RevitNodes
# Import Revit elements
from Revit.Elements import *
# Import DocumentManager
import System
I found this on primer for Revit, is it similar way for Civil 3d ?
Also is there a special line in command to “unwrap” entering elements ?
TransactionManager.Istance.EnsureInTransaction(doc) - line from Revit python script, does same go for civil 3d ?
If you could point me to a place where i could learn a bit more about that would be also very helpful. I am new to python and dynamo.
Thank you for your time
EDIT:
What i would like to achieve with dynamo is to select a corridor link at a station convert it to a feature line and create a new corridor from that feature line (assign targets also). Don’t know if that is possible…
This is a reply from other topic, see it here
It’s helping me out, hope it will help you too
Also, the Dynamo Primer has a chapter for Civil 3D. There is a section with an introduction to working with the Python node as well.
