Use Civil3DToolkit nodes in python
Hello everyone,
I need to use the Civil3DToolkit nodes in my python code.
I did this and got error, can anyone please tell me what is wrong with my package import codes?
Load the Python Standard and DesignScript Libraries
import sys
Load Civil3DToolkit
pyt_path = r’C:\Users\hle\AppData\Roaming\Autodesk\C3D 2020\Dynamo\2.4\packages\Civil3DToolkit\bin’
sys.path.append(pyt_path)
clr.AddReference(‘Civil3DToolkit’)
import Civil3DToolkit
Add Assemblies for AutoCAD and Civil3D
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
Import references from AutoCAD
Import references from Civil3D
The inputs to this node will be stored as a list in the IN variables.
surfaces = IN[0]
solide =
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
        for s in surfaces:
        	solide.append(s.TinSurfaceExtensions.CreateSolids(15, 0, ""))
        # Commit before end transaction
        t.Commit()
        pass
Assign your output to the OUT variable.
OUT = solide
clr.AddReference('AutoCADNodes')
clr.AddReference('Civil3DNodes')
clr.AddReference('Autodesk.Civil3DToolkit')  // import the assembly
import Autodesk.AutoCAD.DynamoNodes as DA  // assign alias for AutoCAD nodes
import Autodesk.Civil.DynamoNodes as DC  // assign alias for Civil 3D nodes
Perfect, I just need to add two more lines and it works:
clr.AddReference(‘AutoCADNodes’)
clr.AddReference(‘Civil3DNodes’)
clr.AddReference(‘Autodesk.Civil3DToolkit’) # import the assembly
import Autodesk.AutoCAD.DynamoNodes as DA # assign alias for AutoCAD nodes
import Autodesk.Civil.DynamoNodes as DC # assign alias for Civil 3D nodes
from Autodesk.AutoCAD.DynamoNodes import *
from Autodesk.Civil.DynamoNodes import *
Thank you Paolo!
