Create alignment from polyline using DataShapes selection node
I have an issue where i am selecting an object using the SelectAutoCadObjects_Data node from data shapes to select a poly line which results in an output of a _COMOBJECT rather than a dynamo object.
This is the pthon code used.
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('Civil3DNodes')
clr.AddReference('AutoCADNodes')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
#Import References from dynamo
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
editor = adoc.Editor
def Get_Civil_Object(COMObject):
	if not isinstance(COMObject,list):
		COMObject = [COMObject]
	output,handle = [],[]
	with adoc.LockDocument():
		with adoc.Database as db:
				for c in COMObject:
					handle.append(str(c.Handle))
				t.Commit()
		for h in handle:
			output.append(SelectionByQuery.GetObjectByObjectHandle(h))
		return output
OUT = Get_Civil_Object(IN[0])
Hi @hfinklea, why do you want use Data-Shapes?
You can get selection just with Python.
In Civil3d try this code, “true” as IN[0]:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
# Import references from Dynamo
ed = adoc.Editor
def select_objects():
	global adoc
	global ed
	output = []
				acSSPrompt = ed.GetSelection()
				if acSSPrompt.Status == PromptStatus.OK:
					acSSet = acSSPrompt.Value
					hndl = []
					for s in acSSet:
						if s:
							obj = t.GetObject(s.ObjectId, OpenMode.ForRead)
							hndl.append(str(obj.Handle))
				t.Commit()
	for h in hndl:
	return output
if IN[0] == True:
	OUT = select_objects()
	OUT = "nothing"
The code above is not mine. Thanks to the peolple here, who created it.
