Already I’ve asked this but I have not solved this problem yet…
There are various structural frames with varying cross-sectional shapes. These structural frames are supposed to be placed on one curve, and I want to place these structural frame families one at a time from the starting point of the curve, given the distance from Excel.
First,
How can I load a structural frame family with a length defined by Excel?
Second,
I want to place a structural frame sectionA up to 5m from the start of the curve, then a structural frame sectionB (as defined in Excel) from 5m to 10m… what node should I use?
Third,
Section A is used one more time after 37m from the beginning of the curve. Other sections are used repeatedly as well. In this case, can I save the second or third SectionA with a different name with special rules?
If I have to load and place structural framing every single time…
I have so many different sections…
I have to place multiple families by the path…
every family has different sections and have to be placed by path and they must have their length (defined by excel)…
And I want place them, by cumulative distances…
(section A starts at the start of curve, and has length 20m, section B starts at the point that 20m away from the start of curve…)
