How can I make a “If node”
Trying to put out hangers for cable trays automaticly. I Wonder if its possible to use a “If Node”.
Example : If the cable tray has a cable bend, I want the first hangers to be 1. meter away from the bend and the hangers in between to 2.meter
I’m quite new in Dynamo, can you explain a little more please?
Nothing there that can help me with my problem.
But thank you for trying
My problem with the script is that I want to make a script that says what’s in the cable tray, for example if the cable tray is 10m and has a bend at the end then I want the first hanger to be 2m away bend. And the rest of the stretch I want it to be 1m apart
Do you need to use an IF node for this? I haven’t seen your revit file so I’m not sure of your cable tray arrangement. This is just a quick script getting the points at equal lengths across the cable tray starting at an offset of 0.2 and ending at 0.8. Pretty swamped at the moment so i haven’t managed to separate them by metres but it gives you the right idea.
Very crude way of doing it but it works, again we haven’t seen your revit file so I can’t tell if an IF statement is needed:
