Good morning, I have to model cabletray in a 4km long tunnel. How can I do this?
Is there a dynamo script that can help me?
Hi Benedetta, welcome ![]()
Please take the time to read the forum FAQs
Start by getting the tunnel alignment and then work out your offset relative to the line coordinate system. It might also be possible to create a polyline with points, translate the Z value and then offset in the xy plane to the cable tray position.
Then use a CableTray.ByLines node - working example here
They are there as part of the core nodes just that they have been renamed. Try searching for “Element Classes” and “All Elements of Class”
When taking screen shots of the workspace, you can zoom in so that the nodes are readable and use Workspace from Export as Image menu
The overlay indicates the status of a node when they are small - the purple indicates it is from a package
Have a look at https://primer2.dynamobim.org
