where they are ?
import System
clr.AddReference('RevitAPI')
clr.AddReference('System')
struSettings = StructuralSettings.GetStructuralSettings(doc)
OUT = struSettings
Like this:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Structure import StructuralSettings as StruSet
app = uiapp.Application
#######OK NOW YOU CAN CODE########
struSettings = StruSet.GetStructuralSettings(doc)
OUT = struSettings
Sometimes you need to make it clear how you import things. For example if you use DSCore you need to import List from System.Collection.Generic under a specific name to prevent confusion for dynamo/python as List is used in DSCore and in System.Collection.Generic. So you need to import one of them under another name.
Hmm:
I use Revit 2019 and IronPython. You are using CPython3, maybe changing it to ironpython solves your problem.
@leonard.moelders ,
it works in 2022
but not in 2023.1.1.
hmmmm… i think because of CPython 3
My newest Revit Version is Revit 2022 so unfortunately i can not help you any further. I looked up the api, but there were no mayor changes regarding your problem. So it seems that CPython3 is causing problems, as you already mentioned.
Can’t you switch to IronPython in Revit 2023?
Edit:
I tried CPython3 in Revit 2022 and it works:
Tested in Dynamo Revit version 2023.0.1 it working
@Draxl_Andreas
you have CPython3 errors which are not common, you should try reinstalling Revit 2023
