Even AI is not helping me how to make the transition to IronPython2 to CPython ?
f.e. with this code
# Import RevitAPI
clr.AddReference("RevitAPI")
OUT = [i.Name for i in doc.Settings.Categories]
KR
Andreas
Can’t fix an error which you aren’t communicating… What is the warning?
@jacob.small ,
any change makes new errors…
KR
Andreas
And in the first example, if you call doc.Settings as the entire line, what do you get?
@jacob.small ,
i will get category by name… …the code is already a bit progressed
# Import RevitAPI
# Get the built-in categories
categories = list(BuiltInCategory.GetValues())
# Filter categories based on valid categories
valid_categories = []
for category in categories:
if Category.GetCategory(doc, category) is not None:
valid_categories.append(category)
# Get the category names and IDs
category_info = [(Category.GetCategory(doc, category).Name, category) for category in valid_categories]
OUT = category_info
the second example is just like IronPython …
# Import RevitAPI
OUT = [i.Id for i in doc.Settings.Categories]
KR
Andreas
