current template does not work
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
OUT = element
where can i find template that works
KR
Andreas
Ok… that code works
# Access the Revit application and document
app = DocumentManager.Instance.CurrentUIApplication
# Preparing input from Dynamo to Revit
# Do some action in a Transaction
# Your code for actions here (e.g., modify the element, create new elements, etc.)
# Return the output back to Dynamo
OUT = element
ok changes are minimal uidoc is removed, and app is added… (ChatGPT done)
