How to write a code in CPython?
si i created a collector ind dynamo 2.17. Revit 2024…
I am supprised that IronPython2 runs ! and also IronPython3! Whats the difference ?
How can i translate this code to CPython ? is there any documantion in the ned or 2024 packages to learn (f.e. on Github)
accessing Revit API seems to be not working :frowning:
clr.AddReference('RevitAPI')
clr.AddReference('System')
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls)
all_walls = collector.WhereElementIsNotElementType().ToElements()
walls = [i for i in all_walls if i.Name.Contains("STB")]
OUT = walls
https://ironpython.net/documentation/
KR
Andreas
Hello, while trying to solve my problem of displaying the python code (I don’t see it appearing anymore),
I saw that there was an update to 2024.1 dated July 11th
for information
Cordially
christian.stan
@christian.stan
grafik
thats may versions now
:wink: i do it now
KR
Andreas
I have to stay in 2023 for the moment (as I was doing a udapte of 2023, and I saw that your code did not work) to avoid the cafarnaum between our different establishments
Cordially
christian.stan
Using 2024.0 the code ran fine for me when it errored out on with 'str' object has no attribute 'contains', as base python doesn’t have a contains method for strings, so you need to use if "STB" in i.Name instead for the filter of the list comprehension.
@christian.stan @jacob.small ,
i installed Revit 2024.1 and Dynamo 2.18.
i have to correct it runs
i changed this
grafik
collector works!
grafik
KR
Andreas
@jacob.small
i still have an error
walls = [i for i in all_walls if "STB" in i.Name]
is there still a syntex error
What error?
@jacob.small
i tried also this
so the error says no “Name” for “wall”
grafik
Looks like an issue with your imports… I can’t reproduce though.
Confirm you’re working with a wall by taking one wall out of the list and getting the class using something like OUT = all_walls[0].__class__.
@jacob.small ,
that was just a test with the single one…
thats my code, i have 9 walls and 3 of them contain name “STB”
# Access the Revit application and document
app = DocumentManager.Instance.CurrentUIApplication
OUT = walls
And this errors out as before?
If so, what happens if y ou take one wall out of the list and get the class (as noted before) and directory using dir(all_walls[0])?
@jacob.small
grafik
OUT = all_walls
works perfectly
grafik
KR
Andreas
try this
walls = [i for i in all_walls if i.Name.count('STB')>0]
cordially
christian.stan
@christian.stan
still the same
grafik
which library template do you use ?
hmmm :frowning:
KR
Andreas
same librairies (but version 2023)
walls = [i for i in all_walls if i.Name.count('Relevé')>0]
OUT = walls,all_walls[0].__class__
Going to start a zoom in ~2 minutes to do this live and record it so we can see the full end to end process.
Recording is here for anyone who’s interested:
https://autodesk.zoom.us/rec/share/009BUV3-6ACnGyuXM2lyCw7Vh_e4v8gMfJALw8LEGaM7NljpN-v89NWvpo7Vrw_s.RocAzZcugA3IiCu-
Passcode: Fgh4e$@d
Should be good for 30 days or so.
Sadly it didn’t help @Draxl_Andreas as there appears to be a deeper Python blocker impacting even imports within the CPython environment.
Well, you need to update your code with below updated code.
import sys
# Add the path to RevitAPI.dll and RevitAPIUI.dll if they are not in the system path
sys.path.append(r'C:\Program Files\Autodesk\Revit XXXX\AddIns\RevitAPI.dll')
sys.path.append(r'C:\Program Files\Autodesk\Revit XXXX\AddIns\RevitAPIUI.dll')
from Autodesk.Revit.DB import BuiltInCategory, FilteredElementCollector
from Autodesk.Revit.DB import Wall, Element
# ... import other necessary namespaces
doc = __revit__.ActiveUIDocument.Document
uidoc = __revit__.ActiveUIDocument
OUT = walls
@negigulshan903 ,
thanks for sharing, but it is not working… “something” is blocking REVITAPI access, we will find out, what the root cause is…
KR
Andreas
