i try to highlight my openings to “green” when they are cut! But it works just for true not for false, why?
for any reason the “not cut” opening remains also in true… i use spring nodes…
this is the code… is it possible to simplify that… to a for loop where i just ask “IsCut” (?) and i get a list of all my openings …
clr.AddReference("RevitAPI")
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
elements = UnwrapElement(tolist(IN[0]))
out1 = []
cut_el = []
cutU = InstanceVoidCutUtils
for i in xrange(len(elements)):
try:
if cutU.IsVoidInstanceCuttingElement(elements[i]):
cut1 = cutU.GetElementsBeingCut(elements[i])
if cut1.Count != 0:
cut1 = [doc.GetElement(id).ToDSType(True) for id in cut1]
out1.append(True)
cut_el.append(cut1)
out1.append(False)
cut_el.append([])
except:
out1.append(False)
cut_el.append([])
OUT = out1, cut_el
i tried this… i think i have to involve geometry, but i just need booleans!
clr.AddReference('RevitAPI')
clr.AddReference('System')
openings = UnwrapElement(IN[0])
output = []
for i in openings:
output.append(i.IsVoidInstanceCuttingElement)
OUT = output
KR
Andreas
