Hi everyone,
I would like to know if there is an node that allow me to know if I element is joined or not with True/False values.
I found a node from rhythm package but I just need to know if the elements are “joined” or not.
Thank you in advance
Hi everyone,
Hi @JC.Moreno
clr.AddReference("RevitAPI")
elements_list1, elements_list2 = UnwrapElement(IN)
result = []
for i in elements_list1:
for y in elements_list2:
if not JoinGeometryUtils.AreElementsJoined(doc,i,y):
result.append(False)
result.append(True)
OUT = result
Hello @Kulkul ,
Thanks for the answer.
I am looking for a method that tells me only if the element is attached or not without the need to compare it with a second element. This would speed up the search.
Is this possible?
Not Possible API requires second element to check if joined or not.
Hi @Kulkul,
I tried an alternative with the rhythm node but I don’t know how to treat the “null” values in the python script. I have tried “isNull” but without success. I don’t have much knowledge in programming so I guess I’m doing something that might be aberrant.
clr.AddReference(“RevitAPI”)
result =
if isNull:
result.append(True)
OUT = result
@JC.Moreno You don’t need python you can get booleans this way:
Thank you very much @Kulkul.
That’s really the solution to my problem.
