Cut opening script
Hello everyone,
I attempted to create a script to cut openings between pipes and walls. However, the void family I used does not orient correctly to create the openings. I need to know how to make a variable offset that adjusts based on the pipe’s diameter cross-section.
Can anyone provide guidance on how to achieve this?
And I can not upload attachments because I’m anew user but if anyone want to communicate we can text in any app of social media.
hard to say without seeing the family you’ve used. I’ve bumpped your trust level so you should be able to post files for others to reproduce, as well as some images showing what you’re seeing which will help as well.
If you need to post larger files you can use a 3rd party service such as ACC, Dropbox, Onedrive, GoogleDrive, WeTransfer, etc… Just make sure the links is open to all.
@zaidkhader277 ,
that topic is still not clean as OpenSource Tool
here some related topics
