Get the element of the selected edge
It’s probably stupidly simple but i cant figure out how to get the the displayed element id of the selected egde
screenshot1
maybe someone can point me in the right direction, thanks
OOTB, I am not sure how to do that. But using springnodes, we can add an additional output to his node.
Paste the following python script into a fresh Python node.
#Copyright(c) 2016, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
from  Autodesk.Revit.UI import *
sel1 = uidoc.Selection
ot1 = Selection.ObjectType.Edge
refs = sel1.PickObjects(ot1, "Select the desired edges and press Finish")
edges = []
for i in xrange(len(refs)):
	el1 = doc.GetElement(refs[i].ElementId)
	edge = el1.GetGeometryObjectFromReference(refs[i])
	edges.append(edge.AsCurve().ToProtoType())
OUT = edges,el1
Thanks, worked perfectly
@john_pierson Perfect.
How can I return the edge as Edge and no as Curve?
Change this from
to
edge.ToDSType()
Yea i thought about it but a iget an error.
erreor
k, do this instead.
Change this from
to
edge
beyond that, open a new topic and try to explain what you are wanting to do with edges.
Thnaks . i open new topic
Hello guys, while I was searching how to solve this problem I found this solution. It’s exactly what I’m searching for except that with multi-edges from different families it gives me only one family in the output.
So how can we get the family of every edge selected?
