Highlight and Extract Word Text
Hello, I have a question if it is possible that what is highlighted in word can later be exported in a list, this is possible perhaps in pdf files and with some web page, but I would like to know if the same thing can also be achieved with dynamo and word
For example, if this were the text:
Hello World!
This is a test to see if this works
I would highlight:
Hello
this works
Generating the highlight as a list
Likely achievable, as Dynamo can access the office API, and the API for word is fairly robust. I have not seen anyone develop such a tool though, and there may be good existing tools for the purpose.
Extracting specific bits from Word into Dynamo is always such a hassle with the formatting. If you’re just trying to get the images or specific text blocks out quickly before bringing the data into your graph, I’ve been using wordimageextractor.com lately. It’s way faster than trying to script a custom Word-to-Revit image parser. Might save you some nodes!
Might be, but it’s also a bit less stable and potentially problematic for a few other reasons. I have seen others do this, and think a POC could be built as a C# based package in about 30 minutes - just a question scaling from there.
For fun, here’s an example using COM interrop, but I encourage you to work with Open XML.
import sys
import System
from System import Array
from System.Collections.Generic import List, IList, Dictionary
from System.Reflection import BindingFlags
clr.AddReference("System.Runtime.InteropServices")
import System.Runtime.InteropServices
clr.AddReference('Microsoft.VisualBasic.Core')
import Microsoft.VisualBasic
from Microsoft.VisualBasic import Information
import traceback
import time
file_path = IN[0]
lst_search_term = IN[1]
missing = System.Type.Missing
lst_range_found = []
class WordlEnum:
    values Enum from API Interop Mircrosoft Doc , to avoid import lib in clr for Enum
    Word_WdReplace_wdReplaceAll = System.Int32(2)
    Word_WdReplace_wdReplaceNone = System.Int32(0)
    Word_WdReplace_wdReplaceOne = System.Int32(1)
    Word_WdFindWrap_wdFindContinue = System.Int32(1)
    Word_WdColorIndex_wdYellow = System.Int32(7)
# clear session
word_application = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("Word.Application", True))
word_application.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, None, word_application, None)
word_application = None
word_application.GetType().InvokeMember("Visible", BindingFlags.SetProperty, None, word_application, (True, ))
documents = word_application.GetType().InvokeMember("Documents",BindingFlags.GetProperty, None, word_application, None)
try:
    doc = documents.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, None, documents, (file_path, ))
    for search_term in lst_search_term:
        select_obj = word_application.GetType().InvokeMember("Selection", BindingFlags.GetProperty, None, word_application, None)
        find_obj = select_obj.GetType().InvokeMember("Find", BindingFlags.GetProperty, None, select_obj, None)
        find_obj.GetType().InvokeMember("ClearFormatting", BindingFlags.InvokeMethod, None, find_obj, None)
        find_obj.GetType().InvokeMember("Text", BindingFlags.SetProperty, None, find_obj, (search_term, ))
        args = (missing,
                False,
                True,
                missing,
                missing,
                missing,
                True,
                WordlEnum.Word_WdFindWrap_wdFindContinue,
                True,
                missing,
                missing)
        # execute the search engine, highlight, and store result with the start range number
        i = 0
        while i < 5000:
            i += 1
            flag = find_obj.GetType().InvokeMember("Execute", BindingFlags.InvokeMethod, None, find_obj, args)
            if flag:
                range =  select_obj.GetType().InvokeMember("Range", BindingFlags.GetProperty, None, select_obj, None)
                r_start = range.GetType().InvokeMember("Start", BindingFlags.GetProperty, None, range, None)
                if (r_start, search_term) not in lst_range_found:
                    range.GetType().InvokeMember("HighlightColorIndex", BindingFlags.SetProperty, None, range, (WordlEnum.Word_WdColorIndex_wdYellow, ))
                    # add data to lst
                    lst_range_found.append((r_start, search_term))
                    break
                break
except Exception as ex:
    print(traceback.format_exc())
lst_range_found.sort(key = lambda x : x[0])
OUT = lst_range_found
