Hiding and showing the right and left Bubble on Level heads in (multiple) views
Knipsel5I want to Hide and show the right en left level check box in (multiple) views
i have seen some similar topic but i can not even get it to work in one view
Knipsel
I get the following warning:
File “”, line 19, in
TypeError: iteration over non-sequence of type Level
First problem solved
i got this python script running :slight_smile:
That Gr8 but How?? could be kind to elaborate
Ok
DY PL Toggle Grid Bubbles (onder en links aan, rechts en boven uit).dyn (10.7 KB)
Sorry wrong one
Here’s the right one
:grinning:
DY PL Levels Hide or Show Bubble Left or Right (checkbox on or of).dyn (6.7 KB)
Ps it depends on how the levels are made in revit. If it turns out the left or right side.
Thanks a lot work like a charm lovely
Is it possible to get this to accept lists of levels and views? I dont know python well enough to work it out
clr.AddReference('RevitAPI')
app = uiapp.Application
def tolist(obj1):
    if hasattr(obj1,"__iter__"): return obj1
    else: return [obj1]
a = tolist(UnwrapElement(IN[0]))
v = tolist(UnwrapElement(IN[1]))
b = UnwrapElement(IN[2])
for i in a:
	if b:
		i.ShowBubbleInView(DatumEnds.End0,v)
		i.HideBubbleInView(DatumEnds.End1,v)
		i.HideBubbleInView(DatumEnds.End0,v)
		i.ShowBubbleInView(DatumEnds.End1,v)
OUT = 0
does this work for lists of views and levels?
it does work for the selected levels
Cant seem to get it to work for me. I have a bunch of views with one level in them that I want to turn the bubble off on the right side. Is my listing wrong?
DY PL Levels Hide or Show Bubble Left or Right (checkbox on or of).dyn (10.3 KB)
I use these dynamo nodes. I freeze the not required one as needed
Hi Mustafa, can you tell me were the “GetRevitSelection” custom node is available.
Capture
Cheer K
I would also be interested in where to find the “Get Revit Selection” custom node. Graph is erroring out at this node, and I don’t know Python.
Morning Jorge,
I ended up replacing that node with the Springs.Collector.CurrentSelection node which worked.
Thank you @Kai. I’ll try that.
DY PL Levels Hide or Show Bubble Left or Right (checkbox on or of).dyn (18.3 KB)
I tried replacing the custom node, but nothing happened. Can someone check the attached graph and let me know what I’m doing wrong. I am new-ish to Dynamo and new to Python. Any help would be greatly appreciated.
Morning Jorge,
Downloaded your script works on my end see attached vid.
Probably a dumb qs but you are selecting the grids in the view prior to running?
Cheers Kai
