Hiding and Showing the Bubble on Level heads
Hello all, I have to show and hide 100’s of bubbles in the level head. So I wrote a small bit of python code by referring to this
but unfortunately it throws an error. The code follows
clr.AddReference('RevitAPI')
app = uiapp.Application
levels = IN[0]
view = uidoc.ActiveView
check = []
for level in levels:
	level = UnwrapElement(level)
	level.IsBubbleVisibleInView(DatumEnds.End0, view)
	#The line below works and returns True or False
	#check.append(level.HasBubbleInView(DatumEnds.End0, view))
#OUT = check
OUT = levels
Error it show is
  File "<string>", line 30, in <module>
Exception: The datum plane cannot be visible in the view.
Parameter name: view
I am confused since the code works for “HasBubbleInView” but not for “IsBubbleInView” or “ShowBubbleInView”
I think not all bubbles are visible in the views that you supply.
You could solve this by trying to catch the errors, like this:
    try:
    except:
           pass
Don’t just copy paste above code, but retype it with the proper indentation.
@T_Pover thanks a lot, didn’t strike my mind that all the bubbles will be visible in the view.
The first thing i learned in python was not to miss any indentation :slight_smile:
