Select grids and turn on / off the bubble
Hi, how could we select those grids and turn on/ off them by using python? Anyone has done the code before? (select grids rather than chose view to turn on and off) Many Thanks.
Use an Element Selection node by Category. Then you will need to supply the Grid end (0 or 1) and then if you want to Show or Hide it.
#Sean Page, 2022
clr.AddReference('RevitAPI')
clr.AddReference('System')
grids = UnwrapElement(IN[0])
end = IN[1]
show = IN[2]
for grid in grids:
	if end == 1:
		if show:
			grid.ShowBubbleInView(DatumEnds.End1,doc.ActiveView)
			grid.HideBubbleInView(DatumEnds.End1,doc.ActiveView)
		if show:
				grid.ShowBubbleInView(DatumEnds.End0,doc.ActiveView)
			grid.HideBubbleInView(DatumEnds.End0,doc.ActiveView)
OUT = grids
Hi SeanP,
Many thanks. I have restructured in this way but somehow out2 give me trouble. Even if i make it as a list but still doesn’t work do you know why?
for grid in gridslst:
		if gridtop:
			out1="Top Bubbles Shown"
			if gridtail:
			    	out2="Tail Bubbles Shown"
					out2="Tail Bubbles Hide"
			out1="Top Bubbles Hide"
			if gridtail:
doc.Regenerate()
uidoc.RefreshActiveView()
OUT = out1,out2
What is the error message?
Hi Sean,
IronPythonEvaluator.EvaluateIronPythonScript operation failed.
unexpected indent
then i test it line by line it seems out1 is fine. just out2 has issues. in this case how we get out2 normally?
Looks like there is a space after out1 before the comma.
Hi Sean, dont know why this way works? it seems weird.
		if gridtop:
			if gridtail:
			if gridtail:
doc.Regenerate()
Oh, I couldn’t tell by the post formatting, but yeah now it’s obvious there are issues with your indenting. It should either always be one single tab per level, or four spaces.
@SeanP
Thank you! This will be a huge time saver!
I added some Data-Shapes UI so I could add it to My Toolbar!
@SeanP
Any idea why the script won’t work when I use Data-Shapes? I’m getting the grids, the number, and the boolean but nothing happens in the model. When I use the Code Block it works.
hello, you send a list, dig on this side
Sincerely
christian.stan
I gathered that, how to I convert it to something other than a list? I assumed a code block is also sending a list that is only 1 item long.
edit:
cordially
christian.stan
Thank you so much, that worked! I’ve had this issue before with lists and never knew about this solution.
