Show/Hide level bubbles in multiple views
Hello Everyone.
I found this script from dynamo Forum to show the level bubbles for the current view. see pic 1
But when i try multiples views, it does not work. Can someone please help me how to adjust it for multiple views? I dont know Python very much. pic 2 with error
Here is the python code.
clr.AddReference(‘RevitAPI’)
app = uiapp.Application
a = UnwrapElement(IN[0])
v = UnwrapElement(IN[1])
for i in a:
i.ShowBubbleInView(DatumEnds.End0,v)
i.ShowBubbleInView(DatumEnds.End1,v)
OUT = 0
@Ammad ,
clr.AddReference("RevitAPI")
t  = Transaction(doc, "Show Bubbles")
t.Start()
for i in a:
t.Commit()
OUT = "Done!"
i think i will not solve your issue but your code is more readable </>
KR
Andreas
How do you paste code like the way you did it. I was unable to post it like this.
grafik
At the moment your code is hard to read, as I have no idea what a and v are. Spell out variables using camelCase or some other standard format so that people an understand what you are working with.
But if I assume that v is your view, and a is your list of grids, then I can guess that you need to add a loop mechanism to your views so that it can iterate over all the views, and then iterate over all the grids in the view iterations.
something like:
for view in viewList:
    for grid in gridList:
        grid.ShowBubbleInView(DatumEnds.End0,view)
        grid.ShowBubbleInView(DatumEnds.End1,view)
